my trans needed less than 4.1?????
found an old thread by TDP (former vendor) where he mentioned he removes the fill plug and fills until it starts to spill out then tightens the plug up. probably because he had fluid in bulk and didn't individually measure out each quart. anyway, i dumped in 4 quarts, and id say about 5-6 ounces came out. brand new, dry trans. car is decently level. would u tighten plug, buy another quart and dump a little in, or say nah if it came out the fill plug u should be good?
T56 is 4 qts.
On a new, bone dry, fill using the fill hole you may find slightly less than 4 qts fill the trans because the fluid has not yet "migrated" throughout the tranny & case. If the car is up on jackstands just start motor and run it through the gears then check level again. You likely could add "x" oz to top it off.
Filling tranny through top just pour in 4 qts
