Whos taken the splines off the input shaft with an RXT?
Looks like the clutch hubs are too loose of a fit onto the shaft thus allowing accelerated wear on both parts coming into contact with each other. Did you replace the shaft with an actual new LS1 input shaft or did you just replace it with another used pull out shaft?
Some one needs to rethink this hub design, looks to me the hubs don't engage the shaft with enough area to transfer all that torque so it just wears out over time. Could probably increase the hub width quite a bit and still have room to work. I can see how the single clutch design hub would have a huge advantage as far as wear. Looks like the hubs are hard enough to wear the input shaft like that. Maybe not enough dampening on the discs.
Lots of clutches are made the same way....but dont have the same problem.
The problem is clearly McLeod.
But yes a multiplate of a better design would be good.
they're common in the JDM world, but strangely a rarity for much else. This design is superior in every way and in reality not even expensive ether. I've bought centre hubs for these, and even in rip of UK they're only around £110, so overall the cost to make a clutch like this should not be stupidly expensive.
Perhaps McLeod could lengthen the hubs on the disks to use more of the available input shaft. Using the same center, and add beef rearwards for the rear disk and forwards for the front disk would help tremendously and there looks to be plenty of room to grow contact area with a deeper hub. The hub splines do look to be very sharp as well which probably helps with chatter, but looks to be eating up the input a little too easy.
Anyways something I been thinking about lately;Theres always gains to be had guys, I dont think our typical attitudes of love/hate is the way to assist our vendors in improving their products and engaging in public discussion.
If you aint breaking? You aint racing
Considering that fact, we all need to learn how to provide feedback with more sense and respect so its not so egg shelly and walls of silence will certainly come down.
But I've used ACT twin plates before, which also had thin hubs...and never had any problems like that.
But if the hub is getting it's teeth sheared off and it's wrecking input shafts....that is a serious problem and warranty should be covering all that damage ! Especially when it's not an isolated case.
But absolutely there are better designs out there
McLeod is very popular among the 5.0L Coyote crowd with the MT82 which uses a 23 spline shaft that isn't very stout to begin with. I can't think of a single issue where the disc prematurely wore into the shaft splines like this. Did you replace the disc when you replaced the shafts each time? Or did you reuse the disc with a new input shaft?
#32
The discs and the shaft were replaced the first time. Now the discs and shaft have to be replaced again. not to mention the first time this happended the input was fairly new (i swaped an lt t56 to an ls t56) so im already out 2 inputs.
#33
How long did it take for the new disc to chew through the new input shaft?
Once those hubs were worn, they are doing to chew through a new input shaft because of excessive wear allowing the them to rock on the shaft when on and off the throttle and at idle.
#34
The first time it happend with in a month because i was racing the car often. The second time maybe 10 track passes and 5000 easy street miles. Yeah i def wont try running these discs with a input. Ive really lost my faith in Mcleod, which sucks because i really liked this clutch except for this fatal flaw
#40
Just read your thread on yellowbullet, youve been threw hell dealing with that clutch huh? I started a thread on there its basically the same as this one. I even emailed mcleod with a link to this thread and they havent said a word to me about it. Looks like i have a 1200 dollar paper weight and 900 worth of input shafts as paper weights as well.
