Hall Effect sensor for F-body T56 tail housing?
I did find a solution. Never did it though, but figured somebody might be interested in it,
https://forums.holley.com/showthread...everse-Lockout
Here's another solution from Tick. They made a direct bolt in Hall Sensor.
https://www.tickperformance.com/tick...-tr6060-4l80e/
You could have done the same thing with a speed sensor connected to the pinion yoke. It would work just the same since the output shaft speed sensor is 1 to 1 ratio with the pinion yoke.
