Help please.! Whatís youíre preference for clutch ? - LS1TECH - Camaro and Firebird Forum Discussion
Go Back  LS1TECH - Camaro and Firebird Forum Discussion > CHASSIS, SUSPENSION, APPEARANCE > Manual Transmission
Reload this Page >
Notices
Old 12-02-2018, 09:52 PM
Formula313's Avatar
Default Help please.! Whatís youíre preference for clutch ?
I have a stock 2002 trans am with full exhaust. Iím having that infamous clutch problem. Iím going to upgrade my entire clutch system but need help deciding with the clutch itself. I was thinking a stage2 monster at first but thatís way more than I need. Iíll be driving it on the street and high rev driving occasionally. Iím looking at a stage2 Efortissimo (EFT). Has anyone ever heard of it.??? What do you recommend that can stand a lil abuse?
Formula313 is offline
Old 12-03-2018, 12:09 PM
Chris Paveglio's Avatar
I have a Monster LT1-S (dual, lightweight) and I like it a lot. I autocross (see sig) and I like the smoothness. Very modulatable with stock MC even. Grabs hard if you drop it fast, but good for in town driving too.
BTW what do you mean by "infamous clutch problem"? The one I think of is not disengaging at high revs; not allowing you to shift to new gear.
Chris Paveglio is offline
Old 12-03-2018, 12:48 PM
ddnspider's Avatar
McLeod RST for street, RXT for more track.
ddnspider is offline
Old 12-03-2018, 05:20 PM
stay away from Mcleod RXT
SLP IROC-Z is offline
Old 12-03-2018, 06:03 PM
I'll throw in my 2c...
DDNSpider tuned and has driven my car, so perhaps he could give better insight?
Have an '02 SS vert/6spd (one owner), that Rick Crain did H,C,E, clutch, transmission, etc, etc (the car has performed flawlessly...once Nick did his magic...). Had been through a lot of clutch issues with my "hot rod" (blown 32V '93 T'Bird), so I did a lot of reading and went with the LS 7 setup...
Butter smooth, no drama on the street, and since it's a "cruiser", Power Tour car, has been able to deal with the 400+ RWHP easily...
As I said, just my 2c worth...
CBAR02SLP is offline
Old 12-03-2018, 08:18 PM
ddnspider's Avatar
The RXT is only 1 of the best clutches out there.
ddnspider's Avatar
Old 12-04-2018, 02:32 PM
its a piece of garbage, hubs strip out, strips the input shaft out as well. ive had two of them, never again
Old 12-04-2018, 03:11 PM
ddnspider's Avatar
Sorry you had a bad experience, but plenty of others have it and love it, including those who race. My RST did multiple 1.5 sixty foots @3800lbs of a 2 step in boost.
Old 12-04-2018, 04:55 PM
I was about to say the McLeod RXT has stood up to more abuse then I've seen anything but a sintered iron disk take. They hold well above what they are rated for, the only complaint I have is they are a bit heavy.
IROC Z clearly got a dud or install error, I've seen two that have had that issue and they sell thousands of those RXT's so its a pretty low failure rate.
SLOW SEDAN is offline
Old 12-04-2018, 08:56 PM
thats an rst not an rxt. I have a thread on here with plenty of pics of the damage. Their hubs are weak and dont have enough spline engagement which ruins both. It couldnt hold up to 1.4 60s.
Old 12-05-2018, 10:07 AM
If your clutch isn't fully engaging in the splines sounds like you have other issues. I have installed multiple RXT's without issue and often end up holding much more power then designed. The RXT hubs are plenty strong, they have held up to years of 9 sec passes in a 4k lb car making north of 1100hp with no damage to the clutch or input shaft.
Old 12-05-2018, 10:18 AM
ddnspider's Avatar
Thanks I'm aware of the difference between an S and a X....the company still makes a good product when used and installed correctly. Perhaps you need a sintered iron full race clutch....but again plenty of others have had success, just like Slow Sedan posted.
Old 12-05-2018, 11:00 AM
Indeed, the product works and can back it up with more facts... Manual top 10 list, 5 of which are McLeods.
[color=left=#222222]7.82 @ 176.57 - 1.26 - Monster LT1-RR -- 427 -- Twin 68mm ---------------- 2975 - Leroythesavage[/color]=left
[color=left=#222222]7.98 @ 185.87 - 1.33 - Monster LT1-RR --- 376 -- 98mm ------------------ 3200 - Blue99fbody[/color]=left
[color=left=#222222]8.00 @ 189.31 - 1.40 - Mantic triple ------- 427 --- F1X --------------------- ???? - jaredz28[/color]=left
[color=left=#222222]8.69 @ 156.00 - 1.26 - Mcleod soft loc ---- 402 --- N/A --------------------- 3195 - ls1 joe[/color]=left
[color=left=#222222]8.78 @ 166.79 - 1.44 - Mcleod st twin ----- 325 --- Twin 6266 ------------- 3150 - ATSMATT[/color]=left
[color=left=#222222]8.81 @ 155.05 - 1.30 - Mcleod Twin ------- 398 --- nitrous xxx shot ------- 3500 - Taner[/color]=left
[color=left=#222222]8.85 @ 154.20 - 1.28 - Sof Loc ------------ 418 --- .082 Jet Plate ---------- 3160 - BES Stroked Nova[/color]=left
[color=left=#222222]9.06 @ 163.85 - 1.54 - McLeod RXT1200 - 325 -- S400 Turbo --------------- 3900 - gtistile[/color]=left
[color=left=#222222]9.07 @ 136.08 - 1.38 - Textralia Exo Twin - 370 --- S485 22psi ------------ 3300 - [email protected][/color]=left
[color=left=#222222]9.16 @ 152.19 - 1.38 - Mcleod RXT -------- 347 --- YSi --------------------- 3250 - 69ls6[/color]
Old 12-05-2018, 05:21 PM
Many do have the McLeod work...but there have been a few threads where the splined hubs have failed taking out input shafts with it.....and weirdly usually only one of the hubs, not both.
stevieturbo is offline
Old 12-05-2018, 11:38 PM
I just bought a Diamond stage 2. Nothing but good reviews about it.
wannafbody is offline
Old 12-06-2018, 10:00 AM
Did McLeod stand behind it and ship them a new disk? Every company is going to have a failure percentage but its how they handle it that matters to me. Stock input shaft, stock bellhousing, correct pilot bearing, all that stuff?
Old 12-06-2018, 10:33 AM
Why is everyone arguing about a twin disk clutch in a thread where the op only has simple bolt ons?
OP, if you plan on throwing a power adder on later then a good twin is worth the investment but otherwise just throw a stock ls7 in it.
stoverz28 is offline
Old 12-09-2018, 07:36 PM
Formula313's Avatar
lol thank you I was thinking the same thing. Like why are yíall arguing. So nobodyís never heard of EFT or PPC ?? & ls7 is a option but I want lighter flywheel
Old 12-09-2018, 07:40 PM
Formula313's Avatar
<removed>
Last edited by wssix99; 12-10-2018 at 02:14 PM. Reason: Image of non-sponsor retail site removed.
Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
