T56 to TR6060 conversion (which slave?)
Call me stupid, but I don’t know and can’t find answer.
I’m swapping my F-body t56 out for a tr6060 (out of a ‘14 Camaro SS) for shifter location reasons in my LS swapped 69 c10.
I’m running a monster Stg3 clutch and Monster 18lb flywheel.
My question: will my F body T56 slave and TOB bolt up and work for this tr6060?
That's a good question and hopefully somebody can confirm this but IMO they're one and the same. Could it the same GM part no. for the 4th Gen and the 5th Gen.?
When you search for the clutch slave cylinder on Rockauto from the 2001 to the 2010 you will find different part numbers so maybe not!
Were you able to confirm that the t56 TOB worked with the TR6060? I'm doing this exact same swap right now and would save me a lot of hassle if the T56 TOB would work. I have both the one that came with my trans and an old T56 slave assembly and they are completely different heights.
