three clutch choices
Took the car to the track over the weekend and broke it. It wont shift into gears at high rpm and barely pulls off. You can be in sixth and go into fifth and it just revs and slips then engages. Starting off the line you let the pedal all the way out and it revs barely moves then catches. So time to order a new clutch for the old girl. I have been searching for the last few days and have narrowed it down to three of them. i have searched the forums on here and a high portion are older threads and no car is the same. Its a 02 z28 with a ms4 cam head work all the bolt ons. It will be taking some launches at 4k or so a few times a month on the track and other places. The car makes in the low 400rwph but will be getting sprayed 150 or so and honestly if it will hold it i will do it out of the hole. It has umi suspension and supporting rear end pieces. I drive it hard and it doesnt' see too much street time just to shops and events. The three i am looking at is:
1. Mcleod RST street twin (mcl-6912-07)
2. monster lt1-s twin with light flywheel
3. monster stage 3 or 4
the monster 3 or 4 is much less but single disc and i hear good and bad things about the puck set up in the clutch. i am doing it myself and don't want to destroy this one in a few months and need another. If I need to spend 1200 i do and it is what it is. If you have a better option let me know you guys know what more than me.
Thanks.
Thanks.
None of those. Look for something light. Qtr master has some nice street clutches that reduce moi. Spec x trim is a good choice to imo and it's very light. Rps is always a great choice with their aluminum flywheel but they are very expensive.
it's pretty much a complete myth about a steel flywheel or heavy clutch set up to get it moving. Remember that weight is only good for the initial hit. Anything after that it's just slowing you down.
Grant
Random example,, I got almost 2 seconds on a 1/4 in a VW bug by dropping the 22lb stock steel flywheel and putting in a 11lb steel.. (I built the flywheel) But what I did was make sure the weight that was left was out at the rim, Bugger spun nice,, and it revved way harder though the mid range,, and was good for both front wheels off the ground for about 20',, With a basically stock 1600 CC engine,, its WAS a Baja with a 1 piece front end.. I went thorough a lot of second gear synchro's in that port transmission..
Flywheel was the only change,, ran a custom re-sprung cover with a solid disk..
It pulled harder in the sand too..
