Monster stage 2 clutch tick master wont disengage
I installed a monster stage 2 clutch with new gm slave and shimed it within spec with tick master cylinder with car on jack stands while running the wheels start to spin when i try to put it in 1st gear clutch pedal is about 1 inch below the brake pedal also when shifting all gears feel notchy
Same thing happening with me. Though I've got a Mcleod RXT twin disc clutch. At first, I was running the oem slave, but slapped in a Tick to try and fix the problem but that didn't completely fix the problem.
From what I gather, using the extra long speed bleeder could be an issue with the hydraulic actuation of the slave. I'm planning on dropping the transmission, swapping in a new slave without remote bleeder, and re shimming.
