what is this noise
Old 05-26-2005, 11:11 AM
wlz28's Avatar
Default what is this noise
when I release the clutch when the car is out of gear I can hear a faint rattling sound. But when I push it back in it stops rattling. Any Idea what it is?
Old 05-26-2005, 03:12 PM
glennhl's Avatar
My 94 M6 also rattles. You can especially hear it if you go through a drive-in window, the rattling noise bounces off the wall. It also only rattles with the car in nuetral and the clutch out. I was told that it was the clutch disc making the noise. The noise seemed to go away when I put a new clutch in, but it came back. You may want to search on Camaroz28.com, they cover the LT1 cars better.
Old 05-26-2005, 03:33 PM
gotzaGTO's Avatar
my T56 does the exact same thing and so does my buddies GTO, so I'm guessin its normal, but what ever, if it breaks, then I just have my excuse to get my viper spec T56! but in all seriousness, I would like to know what is causing the sound too.
Old 05-26-2005, 07:46 PM
Shutout's Avatar
I believe that the rattle you are hearing ( my car does it too) is the input shaft. Something about loose tolerances because of the amount of torque the Ls1 engine produces so the imput shaft doesn't snap .
wlz28's Avatar
I posted it overthere before I did here, and still no replies
Old 05-26-2005, 08:41 PM
Peacock's Avatar
It's the cluster gear and input shaft rattling. Totally normal and nothing to worry about.
Old 05-26-2005, 11:18 PM
glennhl's Avatar
Try using "Search" over at CamaroZ28.com. It comes up with a lot of hits when you search "Clutch Rattle." They agree with what most people said here that it's the tranny rattling and that it's normal.
Old 06-18-2005, 01:35 AM
6 spd LT1's Avatar
i may be wrong but it may be that you need a new throw out bearing.
just my $0.02.
anthony
Quick Reply: what is this noise
