LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Manual Transmission (https://ls1tech.com/forums/manual-transmission-14/)
-   -   Where's the bleeder located? (https://ls1tech.com/forums/manual-transmission/361759-wheres-bleeder-located.html)
RrCoX22 Aug 6, 2005 01:35 PM
Can anyone help and tell me where the bleeder it located for the clutch.
JRracing Aug 6, 2005 02:17 PM
It is under the car right above the hydrolic line that goes into the drivers side of the tranny. You won't be able to see it but you can feel it in there. Use a 1/4" ratchet and 7/16 deep well. Slide the socket up in there then put the ratchet on the socket. Dont loosen it up much, just a 1/4 turn will open it. It's not real easy to do so be patient.
Ferocity02 Aug 6, 2005 09:10 PM
Here is a pic you can use to find it. There are two fittings coming out of the slave cylinder pointing to the right. The one on the top, above the one with the red cap is the bleeder valve. As you can see the whole thing is a 7/16" hex drive. You can find the quick disconnect fitting on the side of the tranny, the bleeder is right above it.
http://memimage.cardomain.net/member...5_282_full.jpg
RrCoX22 Aug 7, 2005 01:17 AM
thx yall!!!
© 2026 MH Sub I, LLC dba Internet Brands
