Need some help with my hydraulics MY clutch isnt operating properly and the the hydraulic fluid is really dark gray. I have a mity vac. If someone could just point me in the direction of where to find the bleeder valve so i can flush out mall the crud that would be great. |
There is a bleeder on the drivers side of the trans. It is just above the slave cylinder line. It is a 7/16 or 11 mm hex. You use the 90 degree cone adaptor for the mighty vac & put it in the bleeder hole w/ it just barely cracked. Make sure you keep the reservoir full when you bleed it. |
© 2024 MH Sub I, LLC dba Internet Brands
