Anyone use a spec Stage 4 on the street.
Old 10-26-2005, 12:38 PM
HAULNTA's Avatar
Default Anyone use a spec Stage 4 on the street.
My stage 3 went out after 5000 m and 9 track passes
I am thinking of going with a Spec Stage 4. Does anyone use one on the street?
Can I use my steel flywheel from my stage 3? My car is not a daily driver but is mostly driven on the street for cruising and other fast street activities.
Old 10-26-2005, 04:13 PM
Turnin'LT4's Avatar
I have a stage 4 and I drive it one the street. Well before i started more work on my car i did. It really isn't THAT bad. You just gotta keep the revs up more from a stop. Running a fairly steep (4.11 and up) gear helps out alot. I went through 3 stage 3s in 4 months. Thats why i went with the stage 4. I have about 8k HARD street driving and i looked at it and it still has 50% material left. Your flywheel will be fine to use. I run a billet one.
Old 10-26-2005, 08:00 PM
SMOKIN01TA's Avatar
150 HARD passes and thousands of street miles and mine is still holding
Old 10-27-2005, 07:38 AM
ls1 joe's Avatar
Well as George said they are not that bad. I have one in my car that has over 25,000 miles and ALOT of drag strip passes. I use to drive it every day 110 miles to and from work. It was fine even my wife could drive it. It takes some getting use to.
Now George, get that car done so I can tune it!!!
LS1Joe
Old 10-30-2005, 12:47 AM
mike c.'s Avatar
ttt...anyone else?
Old 10-31-2005, 08:21 AM
NLinnear's Avatar
I don't have a stage 4 but I do have a stage 5. If the 4 is any more street friendly than the 5, then the 4 should be fine for the street.
Old 10-31-2005, 11:07 AM
bmfcamaro's Avatar
just do it. they dont have the springs on them so you dont have to worry about them breaking. clutch drive just as good as my stage 3.
Old 10-31-2005, 04:20 PM
mike c.'s Avatar
the st3 and the st4 are the same. only the st4 has no springs all else is the same.
Old 11-01-2005, 09:45 PM
Turnin'LT4's Avatar
How do you like the stage 5? I am debating going with a stage 5. My disk is almost gone and while the motor is out i am gonna get a new one. Was also thinking about putting in a tilton or quartermaster triple disk. Just don't know if i can make them work with a LT1 t56
