why would the stock clutch break
Old 10-30-2005, 07:46 AM
RealLiveMD's Avatar
Default why would the stock clutch break
If I am using a WOT switch and I'm not pressing the gas between shifts, why should the stock clutch break with a 125 shot? It seems as if there shouldn't be extra HP to deal with because of the WOT switch.
Old 10-30-2005, 10:54 AM
n2ojunkie's Avatar
what doyou mean by "break"? If it breaks the ring around the springs I've done that a couple of times. Are you powershifting? if so you gotta think your spinging the motor up to close to 6200 and then applying all that power to a small disk instantly. I know they use them in the zo6 at 405hp but I dont think they rate them for a instant load, I think they rate them at what they should be able to hold in high gear at wot after its already engaged. your applying all that power at once and I think that ring is the weak link.
Old 10-30-2005, 05:38 PM
RealLiveMD's Avatar
gotcha
