LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Manual Transmission (https://ls1tech.com/forums/manual-transmission-14/)
-   -   Car won't start after Master cyl. install...help! (https://ls1tech.com/forums/manual-transmission/416041-car-wont-start-after-master-cyl-install-help.html)
Xtnct00WS6 Nov 29, 2005 02:24 PM
My car won't start after Master cyl. install.
I turn the key to the on position and all the lights go on, but when I crank it everything shuts off as if I just unplugged the battery.
I checked the wiring harness under the dash and everything looks okay. I pulled the starter and igition fuses and they looked ok. Any ideas?
Syxx613 Nov 29, 2005 02:29 PM
check your battery. sounds like it could be dead.
Xtnct00WS6 Nov 29, 2005 03:51 PM
Just figured it out...
The battery was just fine. I fiddled with the position sensors for the clutch pedal and that seemed to do it. I guess one of them might have gotten knocked loose somehow. I didn't do anything but wiggle the wires around.
Wierd...
Keysplayr Nov 29, 2005 04:53 PM
Yeah, it's the clutch sensor. If it malfunctions, the car doesn't think that the clutch it depressed to allow starting. Glad you found the problem. Mine actually went bad on me, and had to get it replaced. At first I thought it was the Anti-theft junk acting up, or the chip in my key was shot. But, it was indeed the clutch sensor.
Xtnct00WS6 Nov 30, 2005 10:48 AM
yeah...those clutch sensors seem to be quite touchy. I never even unplugged them. To get it to work again all I did was just fiddle with the wires a bit.
It's wierd that everything shut off just because of those sensors. I don't even know which one was causing the problem.
FRDnemesis Nov 30, 2005 11:45 AM
If I'm not mistaken, the top one of for Cruise control, and the lower one is for the safety start.
Jeff
© 2026 MH Sub I, LLC dba Internet Brands
