T56 slave
T56 Slave question
let just say i waited to long to change my clutch and I think something happen to my slave. I heard a pop and the car was not running the same I look under the car and I looked where the clutch breather slot was and it was infested with fluid. I checked my resivoir and its still half full!? Does it ALL leak out or what when the slave gets "over extended"? Also Is the slave inside or outside the trans. on a T56? Anyone I got a slave from an '02?
T56 slave
come one anyone.... inside when i had to change mine it just dint want to go in gear, but when i drop the tranny all of tranny oil went on my hair (which is long and blonde) it was a b**** to come out, but anyways make sure thats what it is
The Slave is inside the tranny. I've had **** for luck when it comes to slave cylinders.
If the slave is leaking, you will eventually lose all the fluid and the clutch will lose all tension.
damn. never hear dof an overextended slave cylinder. if that is what happend. id put a new slave on it and flush out the master and braided line. https://ls1tech.com/forums/manual-transmission-14/. you'll find more info here.
The slave cylinder is housed in the bell housing, and is between the tranny and pressure plate. I don't know how you can "overextend" it, but I do know that leaking could be a sign of it heading South!!!
