Are all T56's Same?
Are all T56's Same?
Ok guys here it goes, what I am planning on doing is, making my 89 camaro iroc a 6 speed, it has the stock 700R4. Now my question is if a T56 from a 93/97 f body the same as a 98/02 f body? Will both trannys bolt on the same on my 350ci camaro? or is one electronic etc... can i use the same bellhousin?
hey anthony....ya i did the swap with a 94 T56 for the reason of the overdrive gear in the 93 was tighter.... 94-97 are best and are a direct bolt but you need to use the bellhousing from the T56. as for 98-02 T56s im not sure im trying to figure that one out right now myself.
