strange vibrating and rattling Well i had my trans rebuilt by Joe a few weeks ago.. everything went fine.. While I had the trans out. i noticed the previous owner installed a Centerforce Dual friction clutch... it looked fine, so I left it there and didnt change it, but changed the slave, master, drill mod.. ect.. Anyways, so when I get above 3300rpms.. i get a rattle in the shifter, and gets worse with rpms.. the shifter even moves slightly to the right with more rpms.. With the clutch in..and sitting at a light, there is no rattling of any kind.. its not loud, but noticeable, and you can feel it in the stick. is this the clutch doing this? or is it something in the trans? |
help?? |
Clutch sounds like it is not balanced. I emailed you yesterday morning. There should not be anything in the tranny that would cause a rattle like that with the clutch in but not out like you described to me in the email. Thanks, Joe |
sorry Joe, I never got that email.. thanks for the reply.. I was thinking about changing it out for a different clutch.. any suggestion for 322rwhp? I was thinking the LS6 clutch.. good stock replacement. |
LS7 Clutch would be the best bet. It replaces both the clutch, pressure plate and flywheel for what the LS6 clutch costs. Thanks, Joe |
© 2024 MH Sub I, LLC dba Internet Brands
