Pilot bearing
Old Jun 6, 2006 | 06:04 PM
Infantrymarine's Avatar
Default Pilot bearing
Need help pulling the pilot bearing. Do not have a puller. What can I do?
Old Jun 6, 2006 | 07:20 PM
Go Texas Tech's Avatar
Go to the nearest Autozone and rent the following 2 tools - Slide Hammer OEM#27033 and Pilot Bearing Puller Attachment OEM#27059.
The two tools together will get the pilot bearing out. The old pilot bearing will be destroyed but will come out.
Old Jun 6, 2006 | 08:58 PM
mrhzk35404's Avatar
You could also ask for a blind hole puller. I did mine with the above setup and it was a very tight fit almost to the point of not fitting."to large"
Old Jun 6, 2006 | 09:05 PM
kingcuda70's Avatar
BHP only way to go:painless.
Old Jun 6, 2006 | 10:10 PM
Schitzo's Avatar
definetly get the blind hole puller. I rented one from autozone and it worked great......5 minutes and I had the bearing out. Do a search for the threads I started and look at one I was asking for help with the pilot bearing.....I have the autozone part # for the BHP
Old Jun 7, 2006 | 10:02 AM
Sounds good thanks a alot!!
