grinding 3rd?
grinding 3rd?
ok so i have a 98 SS with the T56. since ive bought the car it seems like sometimes if im racing and shift hard into third the transmission will grind pretty badly. Also when the car is cold and i either shift from 1st to 4th or just into 3rd it will also grind...... what do u guys think the problem is? and how can i fix it?
Once its warmed up it's usually fine, although 3rd gear will still grind on occassion, probably due to all the mis-shifts with the crappy stock shifter
First thing I would do is get an aftermarket shifter if you haven't already. I got a Pro 5.0, and its been excellent. You'll never miss 3rd again, because it has an offset 3rd gear mechanism, all you have to do it push forward from second and it goes right to 3rd
Also might want to try changing your transmission fluid. Our T56's specify ATF as a fluid, so I drained mine and filled it with Mobil 1 Synthetic ATF. It shifts smoother, but the grind is still there in 3rd when its cold, due to the synchro being worn out I think.
