Ls2 flywheel difference...
Old 06-30-2006, 06:27 PM
nahasapeemapetalon's Avatar
Default Ls2 flywheel difference...
You cant use an ls1 flywheel with a ls7 clutch setup why whats the diff btwn the two. Boltpattern? I assume the ls2 flywheel lines up with the starter the same right?
Old 07-01-2006, 12:59 AM
SS4Matt's Avatar
the LS7 clutch like sits IN the LS2 flywheel....it's kinda weird i don't know how to explain it, but the LS1 flywheel is flat and the clutch kinda sits on top of it, where as the LS2 flywheel has a raised perimeter almost and the LS7 clutch kinda sits inside it....hard to explain as im not an expert, but it certainly looks different
Old 07-01-2006, 09:44 AM
thanks!
There anything i have to do ...like machine the flywheel ...do i have to do anything to the clutch or is it purely bolt in?
Old 07-01-2006, 10:23 AM
Go Texas Tech's Avatar
Originally Posted by nahasapeemapetalon
thanks!
Just bolt it in.
Old 07-01-2006, 11:08 AM
For those who have bought the ls7 clutch kit from fred beans...did the alignment tool for the clutch come with it or do i have to get my own?
Old 07-01-2006, 11:49 AM
You have to get your own.
Old 07-01-2006, 01:40 PM
SS4Matt's Avatar
i got my clutch from T56 rebuilds, and it DID NOT come with an alignment tool either...but i have my old input shaft from my trans rebuild so that works pretty well!
Quick Reply: Ls2 flywheel difference...
