trouble putting in 1st and reverse from stop
What can cause it to be hard to put into first and reverse from a stop? Just bleed clutch a couple weeks ago? No problems shifting at wot. It goes in and does not grind but is hard after the car warms up? This problem came a while ago and had been gone, now it is back? It helps a little to double clutch, but not really.
Mine does this as well, but its been like that since I bought it! Figured it was normal. I think I read that the Drill Mod solves this but I'm just guessing on that one.
Sounds like maybe a teeny bit of air still in the system - heats up and expands, now there's more air to be compressed resulting in borderline 1st or reverse? Just a guess.
Originally Posted by PlatnumStatuz
Bleed your clutch.
Don't know, try it out, your describing the exact symptoms of a clutch that is dragging. Most commonly that is due to air in the hydraulic system. Give it a shot. You said the problem came back and that can happen if it boils from heat or has a leak somewhere.
Definatley sounds like air in the system, I agree with the others that you should have the clutch system bled again. Good luck.. that air can be stubborn to get out sometimes.
