Ram Powergrip HD warranty info? and more...
Old 09-13-2006, 05:57 PM
seminolecjZ28's Avatar
Default Ram Powergrip HD warranty info? and more...
OK, my friend has a 2000 SS and replace his stock clutch with a RAM POWERGRIP HD. Now we had to drill two holes in the pressure plate housing in order for the clutch assembly to get past the pins on the flywheel. So will these holes void the warranty. I ask this because with less that 2K miles and w/o launching evenonce yet on the RAM clutch, it crapped out and only has 1/16th of an inch of friction material on the pucks on the clutch disk. The flywheel was turned before the new clutch was installed. He purchased the clutch set on Summit, if that makes a difference on the warranty info. Also should he go ahead and buy a new/different clutch while waiting on the warranty to possibly replace the unit or just wait to hear back from summite about the replacement.
Old 09-13-2006, 06:15 PM
gd1996's Avatar
Call summit... they have excellent customer service and can answer everything better than most here here.
Old 09-13-2006, 06:48 PM
my buddy did call summit, but before he takes any action, he wanted to get peoples opinions on what to do, may be others have had a similiar experience.
Old 09-13-2006, 09:16 PM
ttt...
Old 09-15-2006, 12:35 PM
94redz28's Avatar
Instead of drilling the pressure plate just knock the pins out with a punch next time. I installed my Powergrip HD without any drilling
Old 09-15-2006, 04:01 PM
2 SSlow's Avatar
when i got the flywheel back form being turned, i installed the flywheel, then decided to push in the pins, only to find out you cant use them. They were a hoe to get out with the flywheel in the car
Old 09-16-2006, 02:34 AM
SPECIALIZED STAINLESS's Avatar
+1 for pushing out the pins... don't drill.
