NEED HELP FAST!!? cant get out of 4th!!
I was drinving the other day when i try to shift out of 4th...so i put in the clutch and try to shift....nope i could not get the sifter out of 4th gear.. so i forced it and thought i had it but nope it came out of 4th but it was like in some weird halfway neutral place i couldnt get it into any gear but 4th after that i even tryed shutting off the car....the clutch engages and disengages fine it seems to be somthing in my gear box...it finnaly seemed to fix itself but i know its a sighn of somthing any ideas ???
wrencher
Sounds like you broke slider keys in your 3/4 snycronizer. It is not uncommon if you search thru the posts here.
Time to upgrade the internals of your trans. So it will be needing to come out.
