Car is at a stop, push in the clutch, put it in first and car wants to roll forward?
What the title says.
If the car is on level ground, and you push in the clutch and shift to first, midway through the shift, the car actually moves forward just a hair. This is without lifting up the pedal. Clutch is depressed the whole time?
Whats the problem?
Whats the problem?
The clutch is not fully disengaging when you push the pedal in. Most likely a hydraulic problem. You probably need to bleed the clutch (try that first) or replace the slave or master cylinders.
