Just got transmission back from T56 rebuilds a couple questions...
Old 09-22-2006, 05:25 PM
Michael Ozorowsky's Avatar
Default Just got transmission back from T56 rebuilds a couple questions...
1) do I need to get a different pilot bearing? The one that is in there is pretty new, stock GM. However, for some reason my slave cylinder had welded itself to the input shaft of transmission. T56 says this poss. happened due to slop in transmission. Should I get some sort of brass pilot bearing or some other? Do you have a part #? I need to know asap, as I'm installing transmission tomorrow and do not want to have slave ever weld itself to transmission again.
2) I need a new slave cylinder now, because T56 had to cut other one off. Do you have a part # that I could give to autozone or something?
Thanks for the help guys.
Old 09-22-2006, 05:35 PM
Kleeborp the Moderator™
MeentSS02's Avatar
You could get a brass pilot bushing if you wish, but I think a new pilot bearing would be fine. Just go to Auto Zone or whatever, and they can get the part number for you right away. They almost always have one in stock...very common item. They could probably also find you a brass bushing as well...it would be for an older model SBC equipped car, and all you'd have to do is compare the size of it to the pilot bearing to make sure it was the right one. Which one is right for you I have no idea...
Slave cylinder...same story. Go to whatever your favorite auto parts store is, and tell them what you're looking for. They usually have them as well.
Old 09-22-2006, 08:03 PM
bigdsz's Avatar
Get a bronze pilot bushing, I paid $1.82 at a local auto parts store. That way you don't have to worry about needle bearings.
Old 09-22-2006, 08:25 PM
what about needle bearings?
Old 09-23-2006, 09:40 AM
bigdsz's Avatar
The grease surrounding the needle bearings dries up, and with no lubricant the needle bearings are pulverized. A friend of mine who is the shop foreman at a local Chevy dealer decided to replace the clutch on his 35 Anniv SS. When he pulled the PP off guess what, he couldn't even find any needle bearings. The tranny input shaft was just wobbling around. The car only had 12,000 miles on it.
Old 09-23-2006, 11:48 AM
MeentSS02's Avatar
Bronze...why did I say brass?
I'm an idiot...
But as far as the pilot bearings go, I've had great luck with mine...never lost a single needle bearing, and my last clutch was in for a long time...
Old 09-25-2006, 05:19 PM
If I pack hi temp grease in there will that help for next time?
Old 09-25-2006, 05:37 PM
jdoyle's Avatar
hey michael, this is jason, i believe that we spoke ALOT over the summer.
1. id go with a bronze pilot bearing, its cheap and alot better than the stocker.
2. ya your favorite parts store should have one for you.
hope this helps
Old 09-26-2006, 12:30 AM
Hey man do you haev a part #? I can wrench, just not a gearhead, I don't want to get the wrong one. I know amber said something about she could get me one. I'll PM her if you like.
Old 09-26-2006, 06:48 AM
MeentSS02's Avatar
I'd get one from Amber...
Old 09-26-2006, 10:41 PM
jdoyle's Avatar
steves got ya covered mikey!
amber should have one for you, just give her a jingle and she'll get you one just as quick as she can.
Old 09-28-2006, 11:49 PM
I need one for tomorrow sat. I was in between houses when I had to start this project, so did this at mom's house and she's peeved that my cars been in there for about 3 weeks so I have to get this done asap
Old 09-29-2006, 10:50 AM
ls1 joe's Avatar
Michael,
Any auto parts store will have the slave and pilot bearing. Tell them you need a pilot bushing for a 69 camaro with a muncie 4 speed.
Thanks,
Amber
