New clutch install is nothing but problems help!
Old 09-24-2006, 09:16 PM
94CamaroZzZ's Avatar
Default New clutch install is nothing but problems help!
Alright im sure you all know, i just finished my clutch instlal and its nothing but a PITA. Teh clutch just gave out a few minutes ago i had to jam:wah: it in to gear to get it home..was acting fine just had a little clutch chatter..the clutch just went to the floor and wont come back up..what happened guys!?
Old 09-24-2006, 11:35 PM
gd1996's Avatar
Bleed the hydraulics!
Old 09-25-2006, 09:36 AM
i already did, the setup had about 400 miles on it already..worked great just some clutch chatter but other than that worked fine..needs bled again?
Old 09-25-2006, 09:48 AM
ls1amit's Avatar
yea man keep bleeding that **** my freinds car took a while to get right like a few weeks.
Old 09-25-2006, 10:49 AM
black01_WS6's Avatar
bleed it some more. the problem is in the hydrolics not the clutch.
Old 09-26-2006, 09:32 AM
Ok guys after it went to the floor i took it home opened the resevoir cap and it was bone dry?...Its leaking somewhere..not out of the bellhousing or quick connect fitting but its up by the MC and its leaking down through the subframe?..by the steel shield that protects the fuel lines..any ideas? thanks..cars a pita..
