??Universal GM flywheel bolts?? I have ARP flywheel bolts from my last clutch, but need GM bolts for the new clutch due to interference with the Textralia disc. The local Advance has GM Flywheel bolts, but they are listed as just that: GM flywheel bolts. Not LS1 flywheel bolts. Are the LS1 flywheel bolts specific to the LS1? Or will general universal GM flywheel bolts be good? Please help, this is all I have holding me up now. |
You need LS1 bolts. They have 11mm threads, you will not find anything anywhere beside a big fastener specialty supplier or GM. You're best bet is to go to the GM parts dept. even if you have to wait. |
DAMN!!!!!!!!!!!!!!!!!! I guess I will call the parts counter at the Chevy and Pontiac dealerships Monday :( . |
Same boat as you buddy! Have arps and was installing tomorrow, but held up on the GM bolt situation. |
:boiling: :pissed: :mad2: :doublepuk I hope I can take a couple days off this week along with working every evening as long as I can to do all of this stuff. Clutch, torque arm, motor mounts, and shocks. By myself (might get an extra pair of hands if he is not busy) in the driveway :headbang:. |
© 2024 MH Sub I, LLC dba Internet Brands
