opinions on my tranny, pics inside
i was having some trouble shifting so i took my transmission out. occasionally i couldn't get into reverse or had a very hard time getting into reverse and third has popped out a time or two. sometimes it has to be forced into first gear as well. i thought that my synchros were worn but when i pulled the tranny out, i noticed that the throwout bearing has more free play than i'd like even though it only has 3k miles. i also managed to snap off the connection to the slave so i'll be getting a new one of those to fix that problem but now my question is, was it a poorly adjusted clutch/shifter or a transmission problem? can anyone tell me if they see anything that warrants a rebuild or will i have to take it further apart to tell?
You need to look at the teeth inside of the slider hubs to see is they are bad. Can not tell from the pics. I would go ahead and reverse the reverve synco hub since you are in there. It may fix that gear.
