Cant figure out what the problem is with my t-56
Old 06-18-2007, 12:47 AM
1slowls1's Avatar
Default Cant figure out what the problem is with my t-56
I just swapped out my old stock clutch to a spec 3/billet flywheel/gm synchromesh fluid and a new slave. Well broke it in around 500+ miles or so then went to the track, launched around 2k, try shifting around 6k it doesnt want to come out of gear until rpms drop to about 5500-5600 then the same thing goin into other gears, why? what is the deal with that?? i never had that problem with my stock clutch. Also the car chatters like crazy of a stop, but if i take off at higher rpms and let out the clutch quick its ok. And sometimes shifting from 3-4th it grinds but only when im jamming through the gears, when im driving normal its fine.
Quick Reply: Cant figure out what the problem is with my t-56
