Throw out bearing reatainer
Throw out bearing reatainer (Fixed) with Pics
Well i was doing a 3rd gear nitrous pull (LOL) and then i pressed in the clutch and brakes to slowed down and put it in neutral. After that the trans would not let me go into any gear with out forcing it or rev matching. The problem is that the clutch wont fully disengage for the shift. I pulled out the slave cylinder and found the metal retainer clip that holds the throw out bearing and the clutch lever together on the boot to the slave. Will that cause the clutch to not fully disengage? I hope so because i just bought a new spec stage 2 plus and i got to fix this thing.
damn jon! you gotta lay off the spray i think youre addicted!
is this the metal retainer clip your talking about? what do you mean it came out on the boot of the slave? was it completly broken off? let me know if you need any help.
Well on top of the throw out bearing retainer clip being broken the clutch disc had one of the springs come out on me. A little piece broke off and it allowed the spring to come out and cause all sorts a of fun noises. I will snap a pic or you guys in case anyone searches this in the future.
Pics:
Pics:
