Mis-shift :(
Old Aug 7, 2007 | 09:37 PM
Iwantamaro's Avatar
Default Mis-shift :(
I was at about 5500 rpms and I accidentally shifted from second to first. The car jerked alot, but none of the wheels screeched or locked-up. I didn't look at the tach to see the rpm's, but I IMMEDIATLY pressed the clutch back in (not positive i even released it all the way). The car seems to still run fine? Do you think my car's ok, and what are the possibilities of problems in the long run..It's a LT1 ???.
I searched and found alot of threads about this topic, but i'm really worried about it and wanted some input on my exact situation
Old Aug 7, 2007 | 09:46 PM
AFASTYZFR1's Avatar
bent pushrod is what normally happens with the ls1, so I guess it would be the same thing......but if it still runs like normal, my guess is you pressed the clutch in fast and didn't over rev the motor
Old Aug 7, 2007 | 11:16 PM
01CaMMMaro's Avatar
its not gonna do anything if its only happened once... no one is always perfect.
Old Aug 7, 2007 | 11:27 PM
nahasapeemapetalon's Avatar
Its fine, listen for problems if you are worried. It happens all the time. I did much worse when i bought my car.
Old Aug 8, 2007 | 07:27 AM
Sprayed1998's Avatar
Ive done it when I 1st got my car.
Old Aug 8, 2007 | 08:06 AM
PureWS6's Avatar
If you bend a push rod you would be able to tell...if you are over worried you can take them all out and check them out....a good saturday afternoon job.
Old Aug 10, 2007 | 03:48 PM
Revelation Z28's Avatar
i did the same thing when i first got mine. luckily i was 3/4 the way out on the clutch and i caught it at 5000.
Old Aug 10, 2007 | 04:52 PM
Zero4488's Avatar
Restricted User
Yea, I never went to 1st but I messed up....lol....
Old Aug 10, 2007 | 10:45 PM
letsrun97z's Avatar
did the same thing 2 weeks ago6th to 2nd on the freeway. i felt like a dumbass! caught it right away then was worryed for like five min then it was back to wot
Old Aug 17, 2007 | 02:12 PM
onyxxtreme's Avatar
I did it once (I blame it on the stock shifter! ), redlined 2nd gear, and threw it into 1st....I caught it really quick, it was in gear for maybe a fraction of a second.
Found out later on, after pulling out the engine, that I blew up the Pilot Bearing. Luckily it didn't damage the trans....it only left a couple nicks on the input shafts' tip.
Old Aug 17, 2007 | 04:13 PM
styoung's Avatar
i did that once, my car jurked and the low trac light came on, but as far as i could tell it didnt hurt anything. you should be fine.
Old Aug 17, 2007 | 04:51 PM
SUCK MY SS's Avatar
actually you wont always be able to tell a bent pushrod....sometimes they will make noise sometimes they wont...you usually wont notice a drop in power unless a few of them are severly bent....
unless they are bent real good you usually wont be able to tell by just pulling the valve cover....id pull the rockers just in case...lol but im **** when it comes to these things....you may not have any problems but its always good to double check
Old Aug 17, 2007 | 05:05 PM
Sharpe's Avatar
^Agreed with both points, though I wouldn'y actually check them out of laziness.
Did it twice in the 'ol LT1. No probs.
Old Aug 18, 2007 | 01:22 PM
slvr98camaro's Avatar
as long as you didnt keep it there for long, it should be fine.
check and see if you can hear any ticking noises, or the like.. but you should be fine
Old Aug 18, 2007 | 07:15 PM
som6969's Avatar
I also did it as well. But never 2nd to 1st. Mine was 3rd back to 2nd. But it happens
