Adj Master Cyl benefits?
Old 10-16-2007, 07:24 AM
tee-boy's Avatar
Default Adj Master Cyl benefits?
What's the point of going w/ an adjustable master cylinder. What benefit does it provide on a stock clutch or say a spec 3?
Old 10-16-2007, 09:49 AM
blackbyrd's Avatar
allows for change of clutch engagement or in certain cituations where you have installed an aftermarket clutch and the clutch doesnt fully disengage an adjustable master cylinder would allow more or less pedal to compensate for the new clutch.
basically its a rod built just like adj suspension parts where you can lengthen or shorten it depending on application
Old 10-16-2007, 11:32 AM
tee-boy's Avatar
Default ddd
THanks. Is a stock master cyl that has been converted to adjustable just as good as an aftermarket adj master when used on aftermarket street/strip clutch?
Old 11-25-2007, 10:23 AM
tee-boy's Avatar
Default ddd
Let me answer my own question. Yes.
Old 11-25-2007, 12:09 PM
blue98Z's Avatar
Yes and no. I went to a Ram Adjustable and it wasn't allowing my transmission to fully disengage so I went the Mcleod unit which is a race unit and it fixed that problem.
