Reverse funky after new clutch???
Old 10-25-2007, 10:20 AM
Destru6969's Avatar
Default Reverse funky after new clutch???
I just got my LS7 clutch finished last night and while I was at it I changed the tranny fluid (Mobil1 ATF), but now it is waaaay easier to put in reverse. Before I had to kinda force it over, now it's just like any other gear. The only thing I changed was that I pulled out what looked to be a skip-shift eliminator. Funny thing is my skip-shift worked until I got it tuned out when I installed my cam. Maybe it was installed on the reverse lockout solenoid?
Old 10-25-2007, 10:27 AM
SS101's Avatar
Old 10-25-2007, 10:51 AM
Jon5212's Avatar
have you tried putting it in reverse while you are moving forward? Hopefully the gate still locks you out of it.
edit: and yes those plugs and be swapped between the two.
Old 10-25-2007, 11:17 AM
Redlinez's Avatar
You may need to rebleed your slave. I had problems shifting into any gear when I put Mobil1 in mine a while back. Wierd.
Old 10-25-2007, 01:08 PM
Destru6969's Avatar
I tried it and it does lock reverse out. If I put it in reverse with the key off, it feels like it did before and thinking back on it the eliminator was connected to the rear solenoid, so I guess that's what it was. Thanks guys!
Old 10-25-2007, 01:11 PM
Destru6969's Avatar
I've noticed it's a little more notchy with the Mobil1, but it feels great. My fluid that came out was black
Old 10-26-2007, 10:24 AM
Redlinez's Avatar
I'm telling you, if your trans has stock internals, use the regular ATF. Mine felt like the synchros were gone after one day of driving with the Mobil. I used Walmart Supertech fluid and it was like new again immediately.
