What type of Tranny Fluid?
Old 10-27-2007, 12:41 PM
tilly's Avatar
Default What type of Tranny Fluid?
Hello,
I just did a motor swapped and managed to pill half my tranny fuid all over my garage floor. And I am wandering, what type of oil people put into there transmiison. I know it take some sort of automatic fluid, but I dont know exactly?
Tilly
Old 10-27-2007, 12:52 PM
tilly's Avatar
Oh, and lastly how many quarts does it take?
Old 10-27-2007, 01:19 PM
TheLS1Kid's Avatar
4 quarts of any ATF.
Old 10-27-2007, 01:34 PM
tilly's Avatar
There is several types of ATF fluid
Old 10-27-2007, 01:37 PM
OMGWTFBODY's Avatar
I personally used Honda ATF.
I think it calls for Dexron III. or better.
Old 10-27-2007, 02:40 PM
VTC_WS6's Avatar
I'm using Honda ATF right now but I'm not too much a fan of it, than again my RAM
clutch is taking a dump on me so some of my shifting frustrations might be clutch
related..
Old 10-27-2007, 03:17 PM
Grifter's Avatar
Dexron III. It says 4.6 quarts, but it will take about 4.
Old 10-27-2007, 04:21 PM
ae13291's Avatar
dexron III is doing the job for me right now! FYI: i heard people talking about not to use royal purple on a stock T-56! so dont use that stuff
Old 10-27-2007, 04:48 PM
OMGWTFBODY's Avatar
related..
I know mine are.
Old 10-27-2007, 10:20 PM
tilly's Avatar
how would I fill the transmission with fluid with tranny in the car. Its kind of hard to get to the fill plug. I heard a friend of mine said you can fill the tranny through the gear shift.
Old 10-28-2007, 12:13 AM
Grifter's Avatar
Get a suction gun.
Old 10-28-2007, 12:29 AM
Sex On Wheels
will69camaro's Avatar
Shifter has always worked fine for me. I was using GM synchromesh, but gonna look around. My trans took a dump on a road course recently so I'm going to research and see what is working best for those guys to be sure it wasn't fluid related. My fluid was even fresh when this happened (less than 10k on it)
Old 10-28-2007, 04:19 AM
tilly's Avatar
how do I know when the transmission is full if i'm filling it through the gear shift.
Old 10-28-2007, 09:07 AM
Grifter's Avatar
Remove the fill plug and keep an eye on it. Once the fluid starts to come out steady it's full. The same way you would do it if you were filling it through the fill plug.
Old 10-28-2007, 12:54 PM
JonB's Avatar
Pennzoil/gm sycromesh for me.
