T56 pedal removal.need advice
Old 12-08-2007, 02:26 PM
caMnaro's Avatar
Default T56 pedal removal.need advice
I got 6 bolts out that hold them to the firewall.4 around the brake shaft, 2 around the gas pedal, and 2 around the clutch.I removed all the clips, on the brake pedal,clutch, and the wire to the gas pedal.I have most of the electronic connectors off.Am i missing something because it wont pull off at all from the firewall? Thanks mike
Old 12-08-2007, 03:09 PM
jmm98LS1's Avatar
There's one more 13mm bolt on top of the pedal assembly that goes into the dash, you have to lay on your back and look up to see it.
