ls7 clutch swap troubles
I installed a new ls7 clutch with new pilot and throwout bearings the hydrualicswas updated previously to 02 stuff. now the cars clutch wont realease. car will shift on lift but grinds sometimes and is notch. do the ls7 clutch need shims behind the flywheel. what gives any advice is greatly appreciated or the slave took a hike. working fine before install and bleed the system with dot 4
ls7 clutch troubles
with the clutch on the floor the transmission is still engaged. I used a dickey scoggins kit with a ls2 flywheel and ls7 clutch setup. should be a direct bolt in. I cannot shift into reverse it grinds and the car stays engaged at all times like the slave is stuck. I have bleed the system until the pedal com up but it still do actuate the slave cylinder. what gives do I still have air in the system or what. car is undriveable it will shift on the lift but is notchy like it is not fully disengaging.
