Bleeding the slave How do you bleed the slave in the car without making a mess? |
My best guess would be to install a remote bleeder. That's the only thing I can think of that will keep from making a mess. |
a remote bleeder? |
i bought one from a member on here! i cannot remember his name however. it was like 80 bucks shipped and i have it running ou the side of the bellhousing up behind the motor along and strapped it to my fuel rail. it has saved so much time so many times! ill try and find the paper that cam with it maybe it will have his name on it. |
This is the link to the sponsor that sells them here.... https://ls1tech.com/forums/showthrea...bleeder+clutch You have to drop the tranny though, or at least move it back far enough to unscrew the stock bleeder screw and screw in the remote bleeder... good luck |
© 2024 MH Sub I, LLC dba Internet Brands
