How to keep the shifter stick from loosening?
Old 02-02-2008, 01:38 PM
renxwar's Avatar
Default How to keep the shifter stick from loosening?
I have a Pro 5.0 shifter, and a Lous Short Stick. It seems like every 2 weeks the bolts are loosening up. I have to keep the allen wrench with me in my console just to tighten it up. I had the shifter gasket inbetween, but thats since been chewed up by the tightening and loosening. I locktite'd the bolts and that didn't seem to do anything. Any other suggestions? Does anyone else have this problem?
Old 02-02-2008, 01:53 PM
purdueranger's Avatar
Weld it. My college roomate had this problem and we just welded the stick on there so that it would never come off.
Old 02-04-2008, 11:21 AM
jmm98LS1's Avatar
loctite and lockwashers do the trick for me.
Old 02-04-2008, 11:30 AM
renxwar's Avatar
Yeah I re-locktit'd, and rebolted them up as hard as I possibly could. Lets see how well it works.
Old 02-04-2008, 11:57 AM
Internet Mechanic
BlackScreaminMachine's Avatar
they sell a stick (chap stick) like version of Loctite and it works wonders, try that.
Old 02-04-2008, 02:09 PM
robertbartsch's Avatar
Lock washers and red lock tight.
Old 02-04-2008, 06:08 PM
smokeum99ta's Avatar
Same issue here. I just took out the allen bolts and got longer ones and used a nylon lock nut on the other side, never had an issue since.
Old 02-04-2008, 08:44 PM
Eskimo's Avatar
I was gonna suggest all-metal lock nuts. You can usually find them at Ace hardware, but any lock nut will help.
I've got to wonder if you haven't wallowed out the hole in the shifter though, sure sounds like it.
Old 06-19-2015, 02:39 PM
Midnight02's Avatar
Sorry to bump an old thread, however I'm fighting with the same issue. Anyone know the size bolts that are used to mate the Lou's Short STick to the Pro 5.0 shifter?
I can get metal lock nuts and go with red loctite, however I believe I like the longer bolt + nylon lock nut idea posted above the best.
Quick Reply: How to keep the shifter stick from loosening?
