Is this leak from my slave? *Pics* I found this leak coming from my transmission. This looks like its coming from the bolts at the bellhousing. Can you guys help me out? Is this my slave? http://i4.photobucket.com/albums/y11...3/DSCN0143.jpg http://i4.photobucket.com/albums/y11...3/DSCN0141.jpg |
Its hard to tell from the pics but it could be a few things. Could be a leaky slave. Have you bled it lately? Could be oil, possibly the rear main seal. Or could just be a lil leak from the oil drain plug/filter. |
Hard to tell but it looks like motor oil....Id check the rear main |
Originally Posted by ErikElvis
(Post 8794378)
i had the same leak, very minor looking, few drips under the car every few days... turned out to be the frost plug in the end of the crankshaft (right behind the pilot bearing) you will have to pull the trans, if it is not leaking from the slave or the rear main... chances are its the plug. good time to do some upgrades in there if you haven't already! |
Originally Posted by KyleLs1
(Post 8794441)
i had the same leak, very minor looking, few drips under the car every few days... turned out to be the frost plug in the end of the crankshaft (right behind the pilot bearing) you will have to pull the trans, if it is not leaking from the slave or the rear main... chances are its the plug. good time to do some upgrades in there if you haven't already! Good idea...I would go ahead and make all those changes now and fix all the seals while its apart |
Well i plan on getting a new clutch installed in the next week or two so i guess i'll have to wait to what the leak is. I just assumed it was from the slave because the clutch half ass works at higher rpm's now. I'll tell you guys what the fluid is tomorrow. I'll check and see if the leak is on the ground. |
I'm 98% sure it is not oil. |
Yeah if your getting a new clutch you def should be able to tell where its coming from. I know the slaves are finicky when being tightened after being bled. |
(Post 8794498)
The rear main seal is a pretty easy fix as well. So you'll be alright whatever you find. :thumb: |
(Post 8794528)
The rear main seal is a pretty easy fix as well. So you'll be alright whatever you find. :thumb: I'll update this thread tomorrow when i know exactly what the fluid is. |
Originally Posted by BayAreaSS
(Post 8794547)
Thats good to know thanks man. :cheers: I'll update this thread tomorrow when i know exactly what the fluid is. good luck man, hopefully it wont be too painful |
my cam sensor seal was leaking...i had to pull the intake to replace it. also my inputshaft seal on the tranny was leaking too. |
Ok guys i got under there and took a quick sample of the fluid that is leaking. It seems to be brake fluid that has turned black. It does not feel or look like oil which makes me happy |
Yeah it looks like brake fluid. |
I just have to take it easy until i get the new clutch and break it in. I can't enjoy the new power for a while :bang: |
© 2024 MH Sub I, LLC dba Internet Brands
