Ls2/M12 Clutch Quesion
Old 03-01-2008, 09:08 PM
Warsheep's Avatar
Default Ls2/M12 Clutch Quesion
I am planning on buying a spec stage 3+ setup from someone on here that has a 02 ws6 trans in there car, I have a 05 m6 gto that dynos 438whp with a ms3 and will be getting a 150kit in the future. Now this seems like a dumb question but I might aswell ask before I buy it. Will this clutch work on my car because for some reason spec has two different part numbers for this kit, one for the ws6 and one for the gto. Now would anything be different that this wouldn't work on my car?
Thanks,
Marc
Old 03-02-2008, 10:13 AM
Warsheep's Avatar
anyone know....
Old 03-02-2008, 03:45 PM
DONAIMIAN's Avatar
The GENIII uses a different flywheel than that GENIV. You can use the GENIII clutch if you use the GENIII flywheel and vice versa.
Old 03-02-2008, 11:57 PM
Warsheep's Avatar
Well I would be buying the clutch and flywheel from the guy so I guess then it should work.
Quick Reply: Ls2/M12 Clutch Quesion
