grinding noise from T-56
Ok guys I have a problem with a bearing grinding and I do not know which one it is. When I am crusing going to shift and I hold in the pedal in and put it in gear for a few seconds I hear a loud grinding noise the noise will stop if I pull it out of gear,if I put it in another gear after a few seconds the grinding comes back all this happens while crusing, nothing happens from a stop. Also, it shifts fine with no problem.
