cant get into gear???
Old 03-04-2008, 08:22 PM
94gr33nTA's Avatar
Default cant get into gear???
i have a 94 trans am and i just replaced the throw out bearing and clip. i put it all back together and it feels like a clutch and the car will start, but when the car is started it will not go into gear and when off it will. i had trouble gettinf the clutch fork back on over the throw out bearing and not positively sure i have it on all the way or right...?????
Old 03-05-2008, 11:24 AM
TXZ0603's Avatar
do you have a hyd clutch
air in system?
Old 03-05-2008, 06:19 PM
94gr33nTA's Avatar
ive got a hyd clutch... i just took down the transmission and clutch again today and foud a piece of metal that looks like it broke off the old throw out bearing that was stuck in the pressure plate... i have to put it back together to see if it help...
