Clutch Bleeding Problems...
Old 03-09-2008, 05:44 PM
vetteboyc5's Avatar
Default Clutch Bleeding Problems...
This is for a 99 vette, but Camaros have the same basic system..
I have a new slave cylinder and remote bleeder..
stock master cylinder.
after bleeding for about a hour I can only get a inch worth of pedal out of it.
when we do open the bleeder we can clearly feel the pedal drop but its just only coming up a inch.. Its definately not enough to drive it..
What gives? Ive read posts where people had little to no problems and I cant seem to get it right to save my life. Ive heard where people use a vaccum pump and that doesnt seem to work..
im close to replaceing the stock mastercylinder but im not sure if that will help..
Am I missing something here or do I just need to keep trying?
Old 03-09-2008, 06:52 PM
shoemike's Avatar
you need to pull the pedal up by hand.
if your remote bleeder has a good check valve,
it will not allow air into the line.
Old 03-09-2008, 07:14 PM
SuperSport4life's Avatar
Try an 01-02 Master they have a revised design might be worth it to change it out. I have an 01 or else i'd be changing my master with my upcoming clutch swap. FYI I have 23k on the clock so I think its fine but if it gives me a problem its getting changed out faster than a rabbit gets F*cked
Old 03-10-2008, 07:24 PM
89Formulaws6's Avatar
see i've never had a prob with my clutch once, and i'm upgradeing the clutch as we speak so i bought and adj master idk if its even worth installing if i've never had a prob.
