Shaking.
Old 03-10-2008, 05:01 PM
stangkid's Avatar
Default Shaking.
My car shifts into all gears just fine but for some reason when i put it in 6th gear the whole car starts to shake really bad. it just started doing this last week. If anyone knows what it might be please HELP!!!
Old 03-10-2008, 05:21 PM
thesource's Avatar
Start with the u joints in the driveshaft . If thats not it , work your way toward the transmission . You could have a bad yoke on the driveshaft or a worn out rear tail housing bushing in the trans .
Old 03-10-2008, 09:01 PM
stangkid's Avatar
but if thats the case wouldnt it do it in all the gears?
Old 03-10-2008, 09:36 PM
thesource's Avatar
It should but might not depending on the speeds you are starting to feel it in .
Old 03-10-2008, 10:09 PM
fuseone's Avatar
mine did the same thing ever since i bought it idk about you but it only happens when im just at a low rpm. if its like mine i dont find it as a problem
Old 03-11-2008, 08:10 AM
stangkid's Avatar
mine only does it in 6th gear at 70mph. that is the only time it does it
Old 03-11-2008, 09:56 AM
thesource's Avatar
Only in 6th ? Does the problem go away at a faster speed ?
