clutch slipping??
Old 05-02-2008, 11:32 AM
bowtie421's Avatar
Default clutch slipping??
i put in a centerforce dual friction clutch this past december, now it is slipping in high gear. i broke it in to their specs, any1 else come across this trouble with centerforce? is their something i should be looking for, any better clutches out there for an 02 z28
Old 05-02-2008, 02:24 PM
thebart455's Avatar
the clutch is shot, when they go out they slip in higher gears first and gradually work there way down. centerforce has had alot of bad rep on there clutches, i would recommend a different clutch all together
Old 05-02-2008, 02:44 PM
transam1998's Avatar
I went through an SPEC and 2 MCloeds in 3 years. After ruining a clutch every 3,000 miles, I bought a Textralia, have had this one for a couple of years. The pedal engages high now, so it's probably getting close again, but it hasn't started slipping yet.
Old 05-02-2008, 02:54 PM
connexion2005's Avatar
ls7 clutch for the win. built on the same modeling as the ls1 clutch with way more hold and disk size.
Quick Reply: clutch slipping??
