clutch pedal on the floor
i just bought me a ls1 tonight.. out playin around in and it and it seems like after i get on it hard thru the gear my pedal becomes limp and just stays on the floor.. then it comes back with firmness like normal
im not a tranny guy.. wats up
very common problem with the M6 f-body. Could be a number of things. My suggestion is to stick a new clutch in it and replace the slave and master cylinder. If your car is a 00 or below, you need to update the hydraulics to the 01+. If your still on the stock clutch and it has a good amount of miles on it, just fix everything at once. Which means new clutch, flywheel, slave cylinder, master cylinder, and do the drill mod.
