wont shift into 3rd!
Old 05-21-2008, 07:44 AM
DanielBws6's Avatar
Default wont shift into 3rd!
hey guys ive got a 00' ws6 m6 and ive done the drill mod and my car shifts fine at high rpms from 1st to 2nd but when i go to hit 3rd at high rpm after hitting 2nd hard its like i dont have enough pedal and it wont go in gear until rpms drop to like 4,000..but if i shift 1st to 2nd easy and then shift 2nd to 3rd at high rpm it goes in fine its like i only have one good shift when im racing..
Old 05-21-2008, 08:09 AM
EPMD's Avatar
Default 3rd gear
I had the same problem last year. When I did the drill mod it seemed to fix it, but the problem would come back if I let the clutch fluid get a little bit dirty. I would flush the fluid and it would shift fine again. Getting a short stick from the WS-6 Store seemed to help alot also.
