Clutch not disengaging? OK... so I have been having an issue getting into 1st and reverse. I know.. first thought is bleed the system. First, a brief history... New master and slave... fresh rebuild.. Spec Stage 4 clutch all with about 5,000 miles and NO track time. I used the method here:http://performanceworks1.com/ls1_clutch_bleeding.htm NO CHANGE. Car will not go into first, when I try and bump it, I can feel the car trying to jolt forward so it's definitely a disengagement problem. Here's where it gets different though. If I shut the car off and immediately back on, it goes right in. If I pull forward 10 feet and pull it out of gear, right back to square one. So, should I try to bleed it from the bottom? Could it be a clutch problem? I know it's going to be "notchy" with the billet keys and carbon fiber blockers... but this is a disengagement issue FOOOO SHO! :) TIA! |
Yes I would bleed it with the conventional method thru the bleeder. Try to crack open the bleeder, have helper push the pedal down & then close the bleeder before the fluid stream stops. Repeat this till the air is gone. It can be tight to get a tool in there to get to the bleeder though. I use a 1/4 breaker bar & a short 11 mm socket. |
© 2024 MH Sub I, LLC dba Internet Brands
