Who makes an adj. slave cylinder for 97 lt1?
So my clutch likes to engage to close to the floor for my comfort. Does anyone make an adjustable slave cylinder for the lt1 cars?
LS1TECH Sponsor
An adjustable "master" from Ram will work in your LT1 car. The master cylinder itself is the same from the LT1 to the LS1 style I believe, but the lines are different.
If you do a search, you should be able to find a write up on how to modify the stocker to make it adjustable also.
Mcleod Makes an aftermarket external slave the 93-97 LT-1 Camaro. 139024 is the part number. You can see a picture of it on mcleod's forum site where they show pictures of the new LT bellhousing.
