1rst gear shakes the whole car
i have a bit of a problem. when taking off in first my whole car shakes. after that the car is fine in all other gears. i also tried taking off in third(by accident) and it did the same thing. its just on the take off. sometimes it sounds like something is rattling down there as if something were loose. i took it to the shop and they couldn't find anything loose or worn. i already replaced the clutch n slave cylinder. someone told me it might be the tranny mount. anyone have some advice?
LS1TECH Sponsor
Did you replace the clutch in order to fix this problem, or did this problem occur after you replaced the clutch?
A lot of the aggressive aftermarket clutches will have some pretty severe chatter especially if the flywheel wasn't replaced or atleast re-surfaced. What kind of clutch are you running?
did you by chance replace the pilot bearing/bushing that is in the rear of your crankshaft? its the piece that the input shaft of the tranny sticks into. if now, it may be worn, or completely shot and is allowing the input shaft to move under the loads that are produced when trying to get a 3600lb car moving. also since you replaced the clutch i am to assume that yo swapped the throwout bearing as well?
karl
karl
was the clutch replaced recently? how many miles are on the setup?
i had a spec stage 1 (with new OEM flywheel) installed on my car in janurary. clutch chattered like a mother for the first few hundred miles and progressively got better. i now got about over 5k miles on the setup and its much better. it still chatters at low rpm take offs, but its not shaking the whole car like it did when i first had it installed.
defintly replace your tranny mount. i thought my tranny mount was shot and threw a autozone/energy suspension mount on it. the difference was phenomenal. and i dont even think my stock tranny mount was bad; the energy suspension one just doest let it travel as much. the only thing that sucks about these mounts is that it raises the tranny a little higher; my shifter is literally pushing out the center console a little bit.
my recommendation: break in the clutch to factory specs (450-500 miles) and start to get on it a little more and more. try to get a new tranny mount on there ASAP and i guarantee it will help suppress the chatter
karl
karl
yeah it came as a kit with the clutch, pressure plate TO Bearing, Pilot Bearing and alignment tool.
when i first got my spec stage 1 kit installed i babied it for 1000 miles. the longer you baby it, the longer the clutch will last. expect that extreme chatter until you get atleast 500 miles city driving on the kit. i was told by the trans shop to double clutch all downshifts and was told by Jeremy at spec to "get on it" as it was still chattering at 1500 miles.
give Jeremy a PM, i believe his handle in SPEC-01
did your problem ever go away? i have the same problem, i had a textralia oz700 installed it had a bout 700 miles on it, then i drove it for 100 miles seems fine, then the next day the pedal was sticking to the floor, it was hard to put in gears so i had it bleed, now my new problem is that the car shakes when taking off from first, any help would be appreciated thanks
ok guys this may sound stupid.. i know its an entirely different world.. but i had a ford ranger that i had the exact same problem with.. the problem was that the universal joints were froze solid.. a u joint that is junk can cause the exact same feeling that you are describing until you get up to a certain speed and the it isnt noticeable any more... check your u joint.. u never know it could be something that small and can easily be over looked..
If anyone else had the same problem, I decided to take the clutch off again and noticed that there was serious wear on only one side of the the pressure plate and flywheel. The shop that was doing the work told me that the pressure plate "fingers" so to speak were uneven. One side is lower than the other. I think thats the reason why it did this. You guys should have yours checked out too.
