ls1 t56 into a lt1 a4 car
I currently swapped a ls1 and t56 into my old lt1 a4 car. Im having a problem with the car not starting. Turn the key and nothing. All the gauges and everything works like normal fuel pump primes and ect. I havent touched any of the old a4 under console shifter wiring. Im guess I need to bypass the neutral saftey switch to get it to start. Any suggestions would be good. Anyone have a picture of the under console harness that the plugs are labeled? Main question I have is there a way I can bypass the neutral safty switch, by tieing the two wires together. And later I will hook it up the the clutch pedal?
Kepp in mind though this way has NO N/S Switch.. I don't have anything wired up to my Clutch Petal, no need IMO and it's a pain in the *** to install cause the Wires are different between the LT1/LS1 Cars.
